Hallo, ich bin gerade dabei mir eine Traction Bar für den ED9 zu bestellen.
Nun habe ich vom Händler erfahren das es zwei verschiedene Traction Bar's für den CRX gibt.
Folgende Mail habe ich erhalten:
Please double check however because in Europe there are two variations of the CRX crossmember. The standard is the same as the US version (Innovative part # 59112) with the angle bolt hole pattern. The second more common on the RHD SIR is more similar to the US Integra crossmember and has a straight bolt pattern (Innovative part # 59311). You can find both with pictures on the following page of our site: http://www.swapshopracing.com/contents/en-us/d682.html . Please double check them when you can to be sure we are sending you the one you need.
1. Variante (Innovative part # 59112):
2. Variante (Innovative part # 59311):
Welche passt denn nun an den ED9 ?
Danke und Gruß
