Hi,
I create a topic to present you my Hiji...
I have it since 2007, untill 2009, I work essentially on the suspensions and brakes, although I have only the D15B2 90hp, it allow me to punish with road tires some bigger cars on track in, like Golf GTI, 206 S16 in slick tires...
but they was passing me on the straight line...so I decided to swap engine for one of my favourite Honda engine (maybe my favourite engine!)
D16A9! 130hp, and more torque at low rpm than a B16 (due to long run obtained with the crankshaft)...an really less expensive! I paid it 100€ all included to swap it in my car!
11.
12.
13.
14.
15.
at the same time I was running with this D16A9, I rebuilt an other one:
[flash width=425 height=350 loop=true flashvars=]http://www.youtube.com/v/BIpWPUc3zOQ[/flash]
volumetric ration increase from 9.5:1 to 11:1...with OEM camshafts so the torque @ low rpm was really amazing for a 1,6L NA engine!
I had a map done by a local mapper, the best mapp I have ever seen on this engine...
with a friend we made a hybride gear box:the "Ouje Manuel Gear Box" (Portugal Domestic Market)
with S20 Esi gear box as base, we change some intern parts for:
EG3 ex 94'-95' final drive: 4,437 against 4,25
3, 4, 5 gear pinion from ED7
the max speed was 215-220km/h @ 8000rpm, with a great gear "overpass"
I tested with a friend who had a EJ2 B16a2 swapped with ITR gear box & 4-5 gear EG6 pinion:
2nd gear, 50km/ to 100km/h: 3 cars behind me
3rd gear, 90km/h to 140km/h: 3 cars behind me
2nd gear 50km/ to 150km/h: 3 cars behind me
off course, my EG was weigthing only 820kg with the tank full, I think it help me
DC2, EP3, FN2 Megane RS, golf GTI focus RS MK I, some Elises was behind me...
I advise you this set up, this is the cheaper you can have, for 500€ you can have all the engine necessary to swap it, and the 2 or 3 gear boxes to make the Ouje Manuel gear box
after trying this, I wonder why some B16 are sold 1200-1500€...
but the default of this engin when it is used with high rpm: the rods bearing
I learn the first thing to do is to change the OEM used for ACL race parts.
then, I bend a rod due to this fucking rod bearing...@ at the same time, a friend wished to sell his B18 engine full set up(25000km) to buy a NSX...
it was a good opportunity to swap again, for a 238hp engine ( measured with ITB, but I prefere the simple throttle, it is more efficient on B series)
now with the base map the power is about 215hp...but I'm waiting for an Ethanol mapping
Usually, this engine set up give 235-245hp/22-22,5mkg according to the measure, with SP98 gas, and 240-250hp/22,5-23,5mkg with Ethanol...
now, my actually Setup:
Chassis:
Soldering all the chassis and subframe
rear bar in stainless steel tube 30mm diameter, home made
front RE bi-tube stainless steel bar
Windows:
lexan front glasses
front & rear wipers deleted
Body:
doors lightened
fiber hood (need to be installed)
spoon like rear spoiler
Interior:
4,5kg carbon seat (only one seat for the moment)
RRS steering wheel
ITR Shifter
Prosport Manometers: Oil pressure, Oil Temp,Water Temp
Lambda AEM UEGO manometer
Sparco 12pts rollcage (waiting installation, I really inadvise it to you, fitment is really bad !!!)
Brakes:
Goodridge brake hooses
Renault clio RS II front calipers
Carbone Loraine RC6 front brake pads
282x25mm MG ZR front brake discs (drilled and grooved)
EG6 rear calipers
Carbone Loraine RC5 rear brake pads
EG6 rear brake discs
DOT 5.1
Suspension:
EG6 Front & Rear principal arms
Polyurethane bushings
ITR rear Lower control arms
Blox Front & Rear Camber Kits
ASR subframe
ITR JDM 23mm rear anti-sway bar
ITR JDM 25mm front anti-sway bar
Ohlins ITR Shocks & RS*R Ti Springs
Blox Traction Bar
Front left & right upper wishbones inverted (to get between 3 & 4° of "chase" and more camber in dynamic)
Wheels:
ROH 15"x6,5" rims
Bridgestone Potenza RE720 (195/50/15 on the rear axle, and 205/50/15 on the front axle)
Engine:
B18C6 engine block (25 000km)
Oil pan partition home made
OEM EK9 N1 extra light pulley (800 grams)
AEM Camshafts pulleys
Rocket Motorsport RM22x camshafts
Supertech valves, valves springs & retainers
0.8mm machining of the head (B16A2 head)
Port & Polish of the head (Dremel machined)
Fidanza 3,7kg flywheel
Vision motorsport Ignition wires
NGK iridium sparkplugs
Torque damper
Mishimoto ITR radiator
Silicone radiator Hoses
OEM & aftermarket B series oil leaks
Gearbox:
4.4 final drive
3rd, 4th 5th Mfactory short pinions
Quaife LSD
ITR shifter linkage
Intake:
J's Racing carbon slug with 102mm air filter with aluminium/carbon isolation
65mm Blox throttle
AEBS B series intake manifold (opened and Dremel machined / port polished to improve air/gas blending )
Precision 440cc injectors (waiting the Ethanol mapping)
Exhaust:
Hytech 4-2-1 exhaust header
home made decat pipe (57mm)
Hayame exhaust pipe
Twinloop Muffler
Pics:
24.
25.
26.
27. MAAAAC DOOOOONAAALD !!! PAAALAAAPAAAPAAAPAAAAAAA !!!!!
28.
29.
30.
31.
I will look if I find some track videos, I know I have 2:
the first, I pass a 360 Modena, and 2 turns later my ignition distributor has explosed ,
the second, it is the dead of my second D16A9 on track "clac-clac-clac-clac inside"
