Ergebnis 1 bis 9 von 9
Thema: Fehlercodes
    Standard Fehlercodes
    Hab n problem mit meinem 92er crx, die Motorkontrolllampe leuchtet die ganze Zeit und die Fehlerkontrolllampe blinkt
    Fehlercodes:
    1 mal blinken
    8 mal blinken
    Kann mir da jemand weiterhelfen???
    THX
    Avatar von Kai_ED9
    Glückstadt, Germany, Germany
    Her ist schon mal ne Liste mit Codes:
    Code 0 _____ Faulty ECU
    Code 1 _____ Oxygen sensor A (defective circuit or unplugged / defective sensor)
    Code 2 _____ Oxygen sensor B (defective circuit or unplugged / defective sensor)
    Code 3 _____ MAP sensor - Manifold Absolute Pressure (defecitve circuit or unplugged / defective sensor)
    Code 4 _____ CKP Sensor - Crank Position Sensor (defective circuit or unplugged / defective sensor)
    Code 5 _____ MAP sensor again (mechanical problem / disconnected piping)
    Code 6 _____ Engine Coolant temperature (defective circuit or unplugged / defetive sensor)
    Code 7 _____ TP Sensor - Throttle Position (defective circuit or unplugged / defetive sensor)
    Code 8 _____ Top Dead Center Sensor (defective circuit or unplugged / defetive sensor)
    Code 9 _____ No. 1 Cylinder Position Sensor (only on 1.6L) (defective circuit or unplugged / defetive sensor)
    Code 10 ____ Intake Air Temperature Sensor (defective circuit or unplugged / defetive sensor)
    Code 11 ____ Does not apear to exist
    Code 12 ____ Exhaust Gas Recirculation Lift Sensor (defective circuit or unplugged / defetive sensor)
    Code 13 ____ Atmospheric Pressure (defective circuit or unplugged / defetive sensor)
    Code 14 ____ Idle Air Control (IACValve) (defective circuit or unplugged / defetive sensor)
    Code 15 ____ Ignition Output Signal (missing or defective output signal)
    Code 16 ____ Fuel Injector System (defective circuit or unplugged / defetive sensor)
    Code 17 ____ Vehicle Speed Sensor (defective circuit or unplugged / defetive sensor)
    Code 18 ____ Does not appear to exist
    Code 19 ____ Lock up control solenoid (auto trans only)
    Code 20 ____ Electric Load Detector (defective circuit or unplugged / defetive sensor)
    Klemm man für 3 Minuten die Batterie ab und danach wieder an.
    Mit Glück ist es n' gespeicherter Altfehler und er kommt nicht wieder.
    kann ich ja mal probieren, aber ich glaub das wirklich ein fehler vorliegt, da der crx seitdem ich die fehler haben schlechter anspringt und auch etwas an leistung verloren hat (kommt mir zumindest so vor)
    thx
    hm, hat leider nicht geklappt, der fehler kommt immer wieder.
    trotzdem erstmal THX!
    Hat sonst vieleicht jemand ne idee wie ich die fehler entfernen kann???
    An meinem ex - Crx ist immer die kontrollleuchte vor dem starten für 2 sekunden aufgeleuchtet, was war denn das eigentlich?
    obwohl ich nie probleme hatte nur, das er ab und zu nach kurzstrecken nicht sofort angesprungen bzw direkt wieder ausgeganen ist ???
    Greets
    Avatar von Kai_ED9
    @CRX-Doctor:
    Das ist normal.
    Das ist nur solange die Benzinpumpe noch nicht genug Druck aufgebaut hat.
    und bei nem Freund von mir leuchtet die aber überhaupt nicht auf !
    Und was heißt das ?
    Greets
    Doc
    Avatar von Kai_ED9
    Hmmmm...
    Schon mal die Glühlampe überprüft?
    Avatar von qx08635
    Dortmund
    Wenn die Leuchte nicht leuchtet, sollte Dein Kollege zumindest das Klicken des Relais hören.. das kommt im Regelfall dann, wenn die Leuchte wieder ausgeht.
  1. Fehlercodes Übersicht
    Von Tripower im Forum CRX (AS/ED9/EE8)
    Antworten: 4
    Letzter Beitrag: 02.02.2014, 17:10
  2. EJ9 Fehlercodes!
    Von HondaFrau im Forum 95-2001
    Antworten: 3
    Letzter Beitrag: 18.06.2010, 14:56
  3. Antworten: 12
    Letzter Beitrag: 17.12.2008, 11:09
  4. Fehlercodes....
    Von CWittich im Forum Civic
    Letzter Beitrag: 07.07.2004, 07:03
